8 members (DES57, Joe H, baldeagle, gswbbc, TooMany2count, Rusty Heaps, Cheapskate1229, NJC),
190
Mod | | | Forums66 Topics128,040 Posts1,055,474 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | I need a little help. My work space is VERY restricted and I'm thinking of buying a set of the wheel dollies that are in the Hemmings. There are a few brands and prices. I could get the least expensive, but I want them to be a set that will not have problems when it comes to moving. If you have a good set, which company did you get them from? Did you get the locking casters? Is it okay to work under the truck with it on the dollies? Thanks guys. Any recommendations would be great.
Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | 51bolt: Got mine from Northern. Would not live with out them. Have a block under each axle where the spring U Bolts are this gives me another 8" height no rims or tires. Can move it around shop with ease!!! Sooo Nice to move out in center when working on it or push it out of road when I want to do something else.
Owned for about 3 years, have sledge hammered, welded, torched. Holds does not move. Mine does not have locking brake system I feel I do not need it. popcorn The Truth is Out There (Hope this Helps) | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Popcorn you have me confused? Are you using the wheel dollies with some sort of modifacation? Pictures we need pictures.
Hey when are you heading up here? I could use some help hanging shutters! JK
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Brian: Ok I took the rims and tires off so they were not in my way to work on brakes, axles, ext. When I did this it made everything to low sitting inside the wheel dollys. So what I did was take a cement block and wheel dolly placed at 4 corners under the axles. Raised it aprox. 12 to 14" off of floor. Because my Chest fell into my drawers (belly getting bigger) I can't bend over like I used to. If you are going to leave tires and rims on Then just place a dolly under each tire. Great Idea for moving around shop and out of the road. Couldn't do it with out them. Yes I got to get a digital camera Maws and I have been looking into it. OK I'M A TIGHTWAD!!! popcorn (Need some help, seriously on shutters, piece of cake) Can I say ROAD TRIP!  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 51bolt, I have a set of dollies that I got six years ago from Harbor Freight (I call this company my chinese warehouse). They are excellent, and they are sold by other companies also, and they can be found for around $100 for a set of four. They dollies are completely safe to use while working under the truck (as long as your floor is level). Also, I can easily move the truck around on the dollies by myself. I get a little extra height, when needed, by placing a 2"x12"x2' piece of lumber between the top reinforcement bars and I get about 4-5" extra height Tim Every so often these are on sale for $100: Harbor Freight dollies | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Thanks to you both. I knew you guys would know about them. I have a Harbor Freight close to me and I will go and check them out.
Thanks again.
Mark
