7 members (Forty9, fonz8261, jkreiner, treegrower, Bill Hanlon, Wally / Montana, TexasJim50),
51
0
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Is it common after installing all new pads to have to adjust them a few times? Ill have the wheels to where they will go around 1 turn and have alot of pedal then when i come back home they are free spinning again. Ive adjusted them twice as of now and there getting better every time. Is this a common brake in cycle or? My drums are not in the best of shape but i think there salvagible.
1964 impala ss 1949 chevy 3100
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | If the drums aren't turned smooth and have grooves or ridges, that can happen. Say the new shoes were 1/8" wider than the old ones. The edges of the lining will be rubbing on the sides of the worn area before the face of the shoe contacts the face of the drum. You have to wear all of the edges off before the shoe will seat. The same with ridges and grooves. You are grinding the shoes to fit the drums instead of machining the drums to take new shoes. | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Thanks Jim makes perfect sense!
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What Jim posted makes complete sense if you installed new shoes without turning the drums. I might add that in years past, when a shop turned the drums, they also ground the shoe radius to fit the new diameter. I did a set of brakes on a '50, 3100 where we turned the drums and the new shoes were only contacting at a small portion of the center. You really had to stand on the brakes to stop. http://www.pbase.com/dennygraham/image/115452306dg
Denny G Sandwich, IL
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | In my experience, Huck brakes will need some additional adjustments even if you have the drums turned. It is due to what Denny describes above (new shoe radius doesn't match the drum radius). Nobody offers shoe grinding anymore. After driving a while, the shoes will conform to the shape of the drums. After a couple of adjustments over time, you will have excellent brakes.
Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Uhhhh, not entirely spot on Carl want to be technically correct here. The advantage to the Bendix brake or the Duo-Serve as GM called it, over the Huck brake was that it was a single anchor type with a single adjustment for both shoes. But more importantly this design was self-actuating or self-energizing, meaning the shoes were pulled into the drum by the momentum of the vehicle when applying the brake both forward or backward. This eased the pedal pressure over the Huck style brake. Only the later versions of the Bendix style brake were they self-adjusting, somewhere in the late 50's or early 60's if I remember correctly. My memory is fuzzy as to the exact year GM introduced them, Dave or Jerry can probably zero in on the exact year.
dg
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Good catch DG! I need to quit working on other people's newer vehicles. It is filling the limited capacity of my brain with modern pollution. Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No problem Carl, my role isn't to correct everyone's reply. It's just difficult to cover all the bases in a couple of written sentences. I get criticized for my lengthy answers at times, it's just my attempt to present all the facts, not to be a know it all. The best posts are neither needlessly long- winded nor so brief as to be cryptic yet leave nothing to question. Many discussions on this and lots of other sites are like a cross word puzzle in that you have to dig and search page after page before you see the whole picture. That's the only reason I go into such detail as I tend to do. See....there I go again with another short story. Have a good weekend buddy. dg
| | | | | Joined: Jan 2001 Posts: 1,423 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,423 | In my experience, Huck brakes will need some additional adjustments even if you have the drums turned. It is due to what Denny describes above (new shoe radius doesn't match the drum radius). Nobody offers shoe grinding anymore. After driving a while, the shoes will conform to the shape of the drums. After a couple of adjustments over time, you will have excellent brakes.
Carl This has been my experience.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I have my shoes arched at Brake and Equipment Warehouse in Minneapolis. It makes a huge difference, especially if your drums have been turned. You can send them your shoes to be ground but you will need to get an accurate measurement of each drum and then mark the shoes that go with each drum measurement. The last ones I had done last June cost me 5.00 per shoe. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You're fortunate to have a shop in your area that still does shoe re-arching Don. Not many left now days. Probably been at least 25 years since I had a set of shoes matched to the turned drums, all of them round here expect you to wear them in. dg
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My 1 Ton drums were turned out .040 and I did not have the new shoes ground. It took more than one season of driving for the shoes to show a pattern of complete contact. However, the brakes were excellent from the start. I think this may be because they are oversized and I don't carry loads. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A lot depends on the composition also. I don't know where my friend got the shoes for his truck but they seems to be a harder compound cuz you really had to stand on them to stop. Did stop nice and straight and if you had a good grip on the tiller you could lock them up. He never got to drive it enough to lap in the shoes so we don't know what it would be like after a bit of stop and go. 10 or 15 miles won't tell you much.
dg
| | | | | Joined: Apr 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 26 | To pking75: Was just browsing when I saw your thread. When adjusting Huck style shoes, adjust each shoe up until the star wheel is hard to turn. Your drums then should be unable to be turned. Now back that shoe off until you have very light resistance when turning the drum. Repeat for the other shoe. This will help drive the shoe down to the bottom of the drum so more shoe area will be contacting the drum from the start.
Do this for each shoe. When both shoes for each drum are adjusted in this manner, you can now adjust each shoe up tighter one notch at a time until you feel a slightly heavier drag, but not too much. This should help if your drums are not in too bad a shape.
Regarding Bendix style: The key here is not just that you have both shoes anchored at the top and one adjustment at the bottom for both shoes, but rather the shoes are different lengths and made from different materials. The primary (front) shoe has shorter material, the secondary (rear) shoe has longer material either bonded or riveted to the metal back. The primary shoe is softer (and therefore stickier) than the secondary shoe and tends to grab the drum better as it rotates forward. This makes the primary shoe want to rotate with the drum forcing the secondary shoe into the drum which helps assist application of the shoe into the drum surface. This is why the Bendix style brakes give you a better braking feel than the Huck. It's also why you seem to have to press harder on the pedal when backing up because the secondary shoe now becomes the primary shoe momentarily. The secondary shoe material is harder and does not grab the drum as well. The Huck system should have the same feel either forward or backward as the shoes are the same hardness and operate independently from each other (no rotational transfer of energy). Hope this helps more than confuses. Dave | | |
