1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Brad,
Much appreciated sir, thank you.
One other question. When routing the harness, where is the best place to route it from inside cab to the rear for tail lights? Thanks again,
1950 Chevy 3600 w/ 54 235 motor
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I like the light on the top of the fender! If you don't keep it, I'd work out a deal with you for them. Carl
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I took mine down the DS frame member all the way to the back and then branched left. I protected all my connections (heat shrink) and clamped it well to the frame | | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Carl - if I removed them I'd have 2 holes in my fenders unfortunately. But thank you.
Brad - where did you go from inside cab to outside?
| | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Brad - your truck is beautiful. Truly beautiful.
I guess I'm not doing a good job of explaining what I'm asking. How did you route your wiring harness from inside the cab to the back of the truck? Is there a hole somewhere that allowed you to get them down the frame tail from inside to out? Thanks again, Jonny
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | That main loom you see branches off to the front along the inner fender, all the rear harness connections continue down the firewall and then under the cab. Nothing else is required as the harness branches all come through that large hole in the firewall with the exception of the leads to the starter you see going off to the PS (2-wires, red/blue). https://www.flickr.com/photos/advance-design_parts_co/8129206782/in/set-72157631867396207 | | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Brad - thanks again for taking the time to answer my questions. Hopefully I'll get some time soon to start installing the new harness.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Brad, the engine compartment of your truck is ENTIRELY too clean!
