2 members (WarEagle1, 1 invisible),
172
Mod | | | Forums66 Topics128,284 Posts1,058,522 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | I HAVE A 53 1/2 SHORT BED AND THE RUNNINGBOARD BRACKETS THAT ATTACH TO THE FRAME I SEEM TO BE HAVING A PROBLEM LINING THE BOARD ITSELF UP ON THE BRACKET. IT LOOKS LIKE THE BRACKETS COMING OFF THE FRAME NEED TO BE AT AN ANGLE IN FRONT OF THE REAR FENDERS AND THE ONES I HAVE GO STRAIGHT. AM I WRONG? I HAVE BEEN WORKING WITH A NICE GENTLEMAN FROM WA STATE AND WE ARE PULLING OUR HAIR OUT. THESE BRACKETS TO ME LOOK LIKE THE FIRST TWO OF THE THREE ON EACH SIDE ARE STRAIGHT WITH THE THRID OFFSET TO MISS THE FENDERS IN THE REAR. CAN ANYONE HELP I AM AT A LOSS? THANKS | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Have the brackets been off the frame? They are all different.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | YES THEY HAVE BEEN. I GOT THE FROM THE GUY IN WA. THE WAY THE THREE BRACKETS LOOK TO ME ON EACH SIDE GO FRONT TO BACK , STRAIGHT LONG, STRAIGHT SHORT , AND OFF SET ON THE THIRD TO MISS THE FENDER. LOOKING KIND OF LIKE THIS | | / BUT THE MIDDLE ONE BEING SHORTER. | | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello macdaddy. yes the rear brackets are at an angle for a half ton. if you want to come over and look at mine, you are welcome. call me to make arrangements. 603-485-3652. i am right up the road!
our garage is a non-profit organization
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Check to see if you are installing the rear brackets on the correct side of the frame. If they are installed on the opposite side they may appear to be straight out, in reality they should angle to the rear if installed on the wrong side. This is because the rear bracket is angled to the front in relation to the frame rail as well as the center line of the frame. The front and center bracket being angled to the rear in relation to the frame rail, making them perpendicular to the center line of the frame. | | |
