Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (carbking, GMCJammer51, 1 invisible), 224 guests, and 6 robots.
Topics128,284
Posts1,058,522
Members48,490
I HAVE A 53 1/2 SHORT BED AND THE RUNNINGBOARD BRACKETS THAT ATTACH TO THE FRAME I SEEM TO BE HAVING A PROBLEM LINING THE BOARD ITSELF UP ON THE BRACKET. IT LOOKS LIKE THE BRACKETS COMING OFF THE FRAME NEED TO BE AT AN ANGLE IN FRONT OF THE REAR FENDERS AND THE ONES I HAVE GO STRAIGHT. AM I WRONG? I HAVE BEEN WORKING WITH A NICE GENTLEMAN FROM WA STATE AND WE ARE PULLING OUR HAIR OUT. THESE BRACKETS TO ME LOOK LIKE THE FIRST TWO OF THE THREE ON EACH SIDE ARE STRAIGHT WITH THE THRID OFFSET TO MISS THE FENDERS IN THE REAR. CAN ANYONE HELP I AM AT A LOSS? THANKS
Have the brackets been off the frame? They are all different.
54 3100 with 235
62 flatbed dump C60 with 261
YES THEY HAVE BEEN. I GOT THE FROM THE GUY IN WA. THE WAY THE THREE BRACKETS LOOK TO ME ON EACH SIDE GO FRONT TO BACK , STRAIGHT LONG, STRAIGHT SHORT , AND OFF SET ON THE THIRD TO MISS THE FENDER. LOOKING KIND OF LIKE THIS | | / BUT THE MIDDLE ONE BEING SHORTER.
hello macdaddy. yes the rear brackets are at an angle for a half ton. if you want to come over and look at mine, you are welcome. call me to make arrangements. 603-485-3652. i am right up the road!
our garage is a non-profit organization
Check to see if you are installing the rear brackets on the correct side of the frame. If they are installed on the opposite side they may appear to be straight out, in reality they should angle to the rear if installed on the wrong side. This is because the rear bracket is angled to the front in relation to the frame rail as well as the center line of the frame. The front and center bracket being angled to the rear in relation to the frame rail, making them perpendicular to the center line of the frame.
