4 members (MNSmith, Peggy M, wilbur53, 5 Window 9434), 108 guests, and 3 robots.
Topics128,094
Posts1,056,465
Members48,443
I can't find zero-rust prep step, which is supposed to adjust the ph on metal parts for best paint adhesion. I have used vinegar to wipe down galvanized duct before painting with good luck. Would this be okay if I follow up with a damp clean wipe down? I have a lot of engine parts and suspension stuff cleaned up after hot tanking them, but am concerned about possible caustic influence on the ph of the metal. Help! :confused:
Splash,
Email me off list at [email protected] or call me at 800-725-4960 and We can work how how to get you some shipped.
Splashoil,
Bruce is de man....
Craig
Splash,
Did you get the samples? Should be enough to do 3 gallons of solution. When used in a spray bottle, it should do everything you need to do and wash the neighbor's dog........ Bruce Palmer
[email protected]
Sure got 'em Bruce! Parts washed and painted. I was very happy with the effect on the stuff I had cleaned up. I'll be using a lot of the prep step as things progress. Thanks for helping me keep a little momentum! Will be in touch. grin
