1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 43 Member | | Member Joined: Apr 2001 Posts: 43 | I've read in a few different places that you should never use the same gun to shoot paint that you used to shoot primer. Why is that? Is it really that big a deal? | | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | I have no clue why that would be, i do it all the time and have no trouble.
Brian K
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | It really isn't the gun its the needle and the cap that you need to change. Primer needs a bigger tip 1.5-1.7 to properly atomize the primer and spray right. Although you can get away without it.
The same has to do with the paint 1.3 for Base Clear and 1.5 for single stage paints.
But as I said you can get away without doing that way. Just means you need to open up the materials almost all the way to get a good coat for the primer and single stage.
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
