4 members (37 GC, IHPWR, Hotrod Lincoln, NJC), 141 guests, and 2 robots.
Topics128,141
Posts1,056,780
Members48,454
I replaced my water pump on my 216 truck Chevy and went ahead and replacing thermostat as well. I ordered the thermostat and gasket from Jim Carter and there is a large O Ring included. I am not familiar with this O ring and didn't see one taking the old unit out. Is it necessary and if so, where does it go?
I have never seen an O ring in there.
1951 1 Ton Completed
I looked on the LMC web site and it shows an O Ring along with the thermostat and gasket so I don't know. Unless someone can tell me different, I don't plan on using it..
I believe that the O ring is for some aftermarket Thermostat covers that have a Grove machined into them. They most likely include the O ring to "make sure" to cover all the possibilities.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Brian Moore, I agree, the thermostat works on six and v8 engines.It would be used on aluminum thermostat housings also the swivel neck. I think the vendor puts both gaskets so as to cover both applications. I suspect maybe the cost a little more? If you were to buy the thermostat only $8.50 and a $1.00 flat gasket As it probably wouldn't be much more of a difference in cost including the o ring.
http://i1305.photobucket.com/albums/s554/icecreamman55/0710ct_15_zchevy_350_engine_zpsvix59j23.jpg[/IMG]
_________________________________________________
Steve
