6 members (Hotrod Lincoln, 2-Ton, Wayne67vert, Pete1946, Otto Skorzeny, 1 invisible), 110 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#109328 02/17/2005 11:07 PM
Junior Member
Junior Member
I've read about new latches and taking the bow out of the doors. But I'd like to know if anyone has some "must try" tricks to get the standard latches to catch good. Before I go for major surgery, I'd like to try the best re-hab I can find.
Thanks!
It's as old as me and still going
#109329 02/18/2005 10:03 AM
Hey, bro'
Check This Out
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#109330 02/19/2005 12:06 PM
Z
Z Offline
Alan has a good post on this. I went with a slightly smaller rubber from Steele, still had problems on the drivers door, would close and latch by slaming but would not on a "normal" close. If you tried to just swing it closed it would bounce and not latch tight, but with the (new)strike removed the door would close properly keeping the correct body lines. I tried an after market latch, what a joke, unless I got a bad one it was way off. I purchase a good used one from Jeff at Bowtie Bits, solved my problem, seems the old latch ratchet serations and paw were worn down. You can repair by drilling the latch apart and building up the paw with weld and file it and serations sharper, but the used one worked Great-t-t. Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
