| | | Forums66 Topics128,182 Posts1,057,260 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I have repaired many problems on the truck that the previous owner did not do right. the problem that I am working on now is after bleeding the brakes and rebuilding wheel cylinders the brakes stay applied I emailed this question before and a person said make sure the the brake pedal was coming all the way up it was not the spring was off I replaced the spring and now it comes all the way up. I thought maybe the master cylinder was not assembled right the previous owner said he rebuilt it. so I removed it. I went to the rear wheels and still could not turn them with the master cylinder off the truck. so I broke the line loose on the hydrovac and left the pressure bleed off. then I could turn the wheels the previous owner installed new brake lines I was wondering if he put them on the wrong places or is there a hydrovac problem? the line in the back of the hydrovac that goes to the frame goes to the wheels I don't have a book I am sure someone here can tell me thanks for any help. the line near the center of the hydrovav goes to the master cylinder. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | In what order did you bleed the hydro-vac and wheel cylinders?
Did you you use a pressure bleeder?
| | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | started with the furthest wheel from the master cylinder and worked towards the master cylinder did not use a pressure bleeder ive done this many times on other vehicles and never had a problem | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A pressure bleeder for brake line bleeding on big trucks is not called-for in the Shop Manual until 1951.
Before bleeding at the wheel cylinders, did you bleed the hydro-vac unit at the two bleeder valves?
| | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I only saw 1 bleeder on the hydrovac I will check tonight for an other 1 I tried to post a picture on this site but I could not figure out how | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | There may only be one bleeder on the hydrovac in 1950 - all I know about your year (1950) is shown in this multi-year Shop Manual. The hydro-vac in my 54/55 GMC 2-ton did not work correctly until I followed the suggestion for a pressure bleeder (Chev shows pressure for 1951 and later, so you should be OK) and the bleeding sequence shown in the GMC maintenance manual. I think the GMC sequence might be different - maybe due to the location of the hydrovac? | | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I found the second bleeder I will probably have to wait till the weekend to try it I also have to put the master cylinder back in and I am pretty busy this week I will let you know how I make out thanks for the help | | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | ..... I tried to post a picture on this site but I could not figure out how You can't post pictures here. You have to link to them. Refer to the note in lower left column of this page. | | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I installed the master cylinder and bled the hydrovac and system the way the link said to the brakes still are locked the picture of the hydrovac in the link looks the same as mine I am still wondering if the lines are in the wrong place on the hydrovac but I cannot find a diagram on the internet showing that hydrovac with a description of where the lines go | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 29tons, the input to the Hydrovac from the master cylinder goes into a port just below where a cylinder projects out of the flat plate at the end of the vacuum reservoir, the output to the wheel cylinders goes in the end of the cylinder which projects out from the flat plate, hope that helps. | | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | I have been looking into Hydrovac retrofits recently (for a Canadian military Chevrolet but a Hydrovac should work the same no matter what it is hung on). One of the common problems seems to be that people retrofit a Hydrovac (containing a check valve) onto a vehicle that has a check valve included in the master cylinder. The two check valves in series typically cause the brakes to lock on. The standard solution given is to either swap out the master for an equivalent master without the check valve or to remove the check valve from the existing master cylinder. Another thing to be aware of if you don't trust the previous owner's maintenance skills was that Bendix published guidelines for the bore and stroke that master cylinders should have for the various Hydrovacs depending on the weight of truck they were installed in (and how many wheel cylinders were involved). | | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | all the wheel cylinders stay locked. Last week end I bypassed the hydrovac to see if the truck would work like a manual system and it dose.so some thing is wrong with the hydrovac. but at least I can move the thing around under its own power while I am working on other things | | |
