| | | Forums66 Topics128,079 Posts1,056,306 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | I maybe getting a little over my head with this one, but I just relocated to PA and prefer to get the non historic tags so I can use my 50' 1ton more. To my knowledge it'll have to go through a "safety" inspection at a local shop. My only issue is will they question the diesel that's in there even though that year emissions were not a requirement? I have seat belts and all of the daily drivable features with proper lighting, horn, etc. To my understanding PA classifies the vehicles based on weight. Has anyone had any success's or failures with regular tags?
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Sounds like a specially constructed vehicle . You are going to confruse somebody- that's for sure! Brad (A PA resident would need to answer your question- I just was curious what your state DMV might say about it & looked it up; edit #2 It may just be a "street rod" but look in these links. )
Wrench Fetcher, PhD | | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | No emissions on any diesel in pa tags will run about 200.00 for a one ton. If the truck was just had a engine and trans swap I would do a normal state inspection. recheck your wheel bearing after the inspection they will pull one front and one rear wheels to check your brake lining. | | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | My plan was to talk to the local station and tell them what I have, what I need as far as forms if they're needed, along with things I may have to add or fix before I bring it in for inspection. Its really not a "show" or completely stock truck, but all of the upgrades within the mind of keeping it stock.
| | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | you can go on line and find all the inspection rules and what you need to for tags. what part of Pa are you in ? | | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | In Bucks county Morrisville area | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Wow. I'm glad I live in Va. They barely looked at the title when I changed it and bought antique tags for my 58 gmc. Larry
58 gmc 100 with 350 sbc
| | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | I am over a few in York county if your nj tags are still good run them out that way you can find a Inspection station that some of your coworker use.
Larry W with Antique tags in PA. you cannot haul anything in the truck. which means you can not haul 1 2x4 home from lowes. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Wow. That sucks. I use my truck to make dump runs and even pull my small camper. There may be some mileage limitations insurance wise but my speedometer doesn't work anyway. In Va we don't even have to have a state inspection, but you can bet if you get stopped everything better be in good working order.Larry
| | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | I did some reading on other forums about the PA modified title and most folks found it unnecessary (mainly offroaders, and even some mechanics) unless my truck was lifted sky high on 44" tires I could understand. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
