| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | I replaced my water pump on my 216 truck Chevy and went ahead and replacing thermostat as well. I ordered the thermostat and gasket from Jim Carter and there is a large O Ring included. I am not familiar with this O ring and didn't see one taking the old unit out. Is it necessary and if so, where does it go? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have never seen an O ring in there. | | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | I looked on the LMC web site and it shows an O Ring along with the thermostat and gasket so I don't know. Unless someone can tell me different, I don't plan on using it.. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I believe that the O ring is for some aftermarket Thermostat covers that have a Grove machined into them. They most likely include the O ring to "make sure" to cover all the possibilities.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Dec 2012 Posts: 78 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 78 | Brian Moore, I agree, the thermostat works on six and v8 engines.It would be used on aluminum thermostat housings also the swivel neck. I think the vendor puts both gaskets so as to cover both applications. I suspect maybe the cost a little more? If you were to buy the thermostat only $8.50 and a $1.00 flat gasket As it probably wouldn't be much more of a difference in cost including the o ring. http://i1305.photobucket.com/albums/s554/icecreamman55/0710ct_15_zchevy_350_engine_zpsvix59j23.jpg[/IMG] _________________________________________________ Steve | | |
