| | | Forums66 Topics128,081 Posts1,056,073 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2001 Posts: 35 | Been working on puttin the bed back on the jimmy. it has been off so long i forgot it was ever a truck. it seems that it lists to one side. i blaming it on spring sag i guess. anybody have any better idea? i am puttin in a steel floor rather than the wood. Only change i have made is going ahead and mounting the floating crossmember to the frame 16" back from the front crossmember, and i will have to figger out a diff way to bolt the crossmembers to the frame. My cab mounts are bad, so the cab lists to one side too, causing it to visually look tiltled, tho the measurements arent that far off from the floor. Any reason i can cant fab up some cab mounts that are less sloppy than the originals? | | |
