7 members (Hotrod Lincoln, bobfake, GRNHydra, tclederman, Woodcmiami, Otto Skorzeny, 2-Ton), 43 guests, and 2 robots.
Topics128,091
Posts1,056,034
Members48,433
#1092940 03/22/2015 3:30 PM
Gas Pumper
Gas Pumper
The last spin on adapter I got had a bracket at 90 degrees so I could mount it. Here:
http://devestechnet.com/Images/Projects/FullFlowOil/oilfilter7lg.jpg
What I liked about it is it took the standard FL1 filter. I made a bracket to adapt the location.
The spin-on adapters are all over just about any site I go to, but I don't see a way to mount them. I need another like the one I have. Anyone have any ideas?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve #1092948 03/22/2015 3:59 PM
Gas Pumper
Gas Pumper
I found it. For the record, its a TransAdapt 1028 available in alot of places once you know that! If fits the PH8A, 1515 filters that are very popular. I need to learn to document stuff better!
Deve
The Think Tank
Deve #1092956 03/22/2015 4:23 PM
That would be spelt Trans-Dapt 1028 Single Filter Relocation Bracket
Available from many sources.
Deve #1093030 03/22/2015 10:21 PM
Gas Pumper
Gas Pumper
Updated my article on full flow filters to include that. Thanks!
Deve
The Think Tank
Deve #1093043 03/23/2015 12:00 AM
Will this work on a 1950 216?
Harold
Harold
Deve #1093044 03/23/2015 12:09 AM
No - that filter head is for a full-flow filter. The 1958-63 261 engine in the first GM engine with a factory full-flow filtering capability.
A 216 would be normally/originally plumbed for an optional by-pass filter.
However, Jim Carter sells a by-pass filter-head that uses a spin-on filter.
Deve #1093059 03/23/2015 1:19 AM
Gas Pumper
Gas Pumper
Altho... I wonder if the only difference is the size of the orifice. If that were the case, since the stock hoses have a 1/8" orifice, I wonder why it wouldnt work just fine, as long as you make sure you restrict the size to 1/8"?
Deve
The Think Tank
Deve #1093074 03/23/2015 1:45 AM
H Online: Content
1/8" is too big. Use a 1/16" orfice. I fit spin-on filter adapters with a Holley carburetor main jet, drilled out to .0625". Inlet or outlet fitting- - -doesn't matter which one.
Deve #1093079 03/23/2015 2:11 AM
Thanks, Jerry
Deve #1093274 03/23/2015 11:35 PM
Gas Pumper
Gas Pumper
You have mentioned the Holley main jet before. Does this main jet have threads on both ends or what makes it good for a fitting? I really don't know! Once I do understand it, I should include it in the full flow article with a caveat that IF you have a bypass system then....
I got a call the other day from a guy who has a 261 but a 1956 model. He had the spin on adapter and could not for the life of him figure out how he only has 8 pounds of pressure. I told him the original bypass hoses had a 1/8" orifice on one end, so try adding a 1/8 restrictor. He did, and he had 30 pounds and was so happy! So, I want to write the correct information, so this isn't up for grabs. Thanks Jerry!
Deve
The Think Tank
Deve #1093279 03/23/2015 11:51 PM
Bill Burmeister
Deve #1093281 03/23/2015 11:56 PM
Gas Pumper
Gas Pumper
I know Bill, but does it fit inside a certain size of pipe? or now is this restrictor used? Jerry is known for his ingenuity, so there is something about it that makes sense or he wouldn't mention it.
Deve
The Think Tank
Deve #1093329 03/24/2015 2:51 AM
H Online: Content
OK, one more time- - - - -The original bypass filter canister has a 1/16" hole drilled in the standpipe that controls oil flow through the filter. Whether the original style 1/4" diameter rubber lines are used, or 1/4" or 3/16" OD steel tubing is bent to fit, the adapter for the spin-on filter MUST have a similar restriction built in to prevent excessive oil being bypassed back to the crankcase and loss of oil pressure to the engine. Pick one of the adapter fittings that are used to reduce the pipe threads in the spin on filter mount, and drill and tap a 1/4"-28 thread into its inside diameter. Then screw the Holley jet into it. You now have a restricted fitting to control oil flow and prevent the engine from getting starved for oil. It's really not as mind-boggling as it seems- - - -simple drilling and tapping! I use Holley jets because I have several dozen of them left over from my round track racing days. The thread isn't exactly 1/4-28, but it's close enough for a one-time installation.
Edit: I will probably have to do a photo shoot to show the step-by-step procedure for making a restricted fitting. Then only willfully obtuse people will have a hard time grasping the concept.
Deve #1093332 03/24/2015 3:04 AM
Gas Pumper
Gas Pumper
That all makes sense! Thanks for clearing it up. I can see it being a good idea even if you had to order the jets to do it. Thanks again!
Deve
The Think Tank
Deve #1093411 03/24/2015 2:21 PM
Here's the way I'm going with it. Wix makes a spin on adapter that using bypass filters. It's part # 24755. Wix page for 24755. It uses a 5/8-18 thread so normal filters won't thread onto it. The filter I'm using is a Wix # 51050. It has a .0625" restriction built in it. Filter restriction restriction measurement
Deve #1093413 03/24/2015 2:32 PM
Deve #1093517 03/24/2015 11:37 PM
Gas Pumper
Gas Pumper
Yes, that is a keeper alright! Thanks Chad!
Deve
The Think Tank
