4 members (J Lucas, TUTS 59, Guitplayer, Otto Skorzeny), 38 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#1092894 03/22/2015 5:15 AM
Hello.
I've found a 235 to replace my 216. The previous owner had it rebuilt. Its out of the car, however, so I have no way of testing it to see if it runs until I put it into my car.
Does anyone have any suggestions as to how I can check the engine before I make the purchase?
Judson
Judson #1092899 03/22/2015 5:47 AM
U
U Offline
Hidiy Judson-
That's a "buyer beware" situation (meaning you), but you should at least make sure the engine will turn over. Look for obvious cracks on the head & maybe see if you can peek under the valve cover. Print off the shop manual engine diagram page or a picture of a complete 235 engine to compare to the one you're looking at purchasing. Make sure all the parts are there.
Another concern is that whoever is selling it may not even know what condition it is in. If the previous owner had it rebuilt, I'd ask for any paperwork/receipts they may have for the parts, or at least ask who did the rebuilding. Ask tactfully, but a "no" answer to that information would be fishy to me.
You don't have to post it, but their asking price will be directly proportional to how much the 'rebuild' parts cost if it was a recent job. New parts for a complete rebuild of a 235 are about $700-$900 (at MINIMUM).
Hope this'll at least get you some thinking points & I hope it works out for you getting a new motor.
Brad
Wrench Fetcher, PhD
Judson #1093009 03/22/2015 8:39 PM
You can start and run a motor for 30 seconds sitting on the floor not hooked up to anything if the motor is all there.
Hook a fuel line up to the fuel pump, drop it in a gas can. Make sure it has oil. Connect a battery with a wire to the coil and start it up.
Just a thought...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Judson #1093166 03/23/2015 3:48 PM
Unless there is paperwork to prove WHAT work was done 'rebuilt' could mean he gave it a tune up.
Master parts kits are $800 or so, machine work is another $500. You never said what the asking price was, but that would also play a role in how much of a rebuild actually occurred.
Even running it for 30 seconds won't tell you much.
Scrap is $10/100lbs. A 235 is about 600lbs so scrap price is $60... and a full rebuilt motor is $1200-$1500 if DIY.
Now your part is how much do you want to gamble on this guy's story? Me... unless the motor is still wrapped up from the shop, rebuilds do not put much value into an engine... how many miles? Why is he selling? What the motor look like now? All those questions take $100's off the asking price.
And no matter what a seller says, scrap won't be more than $100
Judson #1094720 03/30/2015 11:56 PM
a lot of good advice here .. i have heard the word rebuilt meaning anything from a real rebuild to a valve lap job... pull the spark plus and do a compression test.. or at least look at the condition of the plugs..then grab the fan and hold in on the fanbelt and rock the engine back and fourth.. listen and feel for any clunks
if you cant run with the big dogs...then stay on the porch
http://s202.photobucket.com/user/rcplumley/library/
