| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | martinsr, You must be the one to answer my question. What do you put on a freshly sandblasted exterior truck body. Thanks, Greg
1951 1.5 ton 4400 | | | | | Joined: Jul 2003 Posts: 29 Member | | Member Joined: Jul 2003 Posts: 29 | Greg, go to Wal-mart and pick up some rust converter in either spray can or bottle. Wipe the body down with alcohol then follow the instructions on the lable. It will kill the rest of the unseen rust and turn the metal black. Make a good base primer and then use either POR or Eastwood's rust encapsulator to seal it. They are both sandable.
Use a big enough catapult and even pigs can fly...remember nothing is impossible, impractical yes, but never impossible.
| | | | | Joined: Jan 2002 Posts: 24 Junior Member | | Junior Member Joined: Jan 2002 Posts: 24 | marine clean and then metal ready it's good stuff i used it today on my 62 c10 firewall then i put por-15 on www.por15.com | | |
