3 members (dt235sd, Bucker, UtahYork), 160 guests, and 4 robots.
Topics128,196
Posts1,057,390
Members48,471
so here is a random question but I need help with it. I have a 1953 3100 5-window 1/2 ton with a chevy 350 and a th-350. I am currently laying out my new front brake lines and I am having issues on where to place the front t-block. I figured it should be centered but of course there is a engine and a trany in the way. I have the rear location on my new chevy 10 bolt. that was the easy one...
any thoughts? also note the body is on the truck.
Loving my new (old) '53 3100 5 window!
V
VEW Offline
V Offline
Don't have an AD, but when I ran brake lines on our 56 Nomad, I put the T on the frame by the LF wheel.
~ Victor
1957 3100 - moved on
ok so not centered but did the trick! any issues?
V
VEW Offline
V Offline
No issues. Just continued the line by the front cross member over to the RF wheel.
After you bleed your brakes, all lines and cylinders are filled with fluid. When you apply your brakes, all pressurized equally.
~ Victor
great, THANKS FOR THE HELP buudy!!!
