| | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I am considering re building a 216. Is there a replacement or different connecting rod available today for the original babbitt rods?
I did this once back in the 70's and easily found some rods. What is out there today? Any kind of economical swap?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | you can get them machined for insert bearings. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If using an insert bearing in them is your concern then any decent automotive machine shop should have the capability of reworking them to accept a bearing shell. That was and is a very common modification to the stock Babbitted rods. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Most of the on line vendors have rods that have already been machined to accept inserts. I got mine from Kanter.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Getting the bearings for the machined rods can be a little challenging, especially if you happen to need them in .020" undersize. They are available in .010 and .030 under, but the supply of 20's has just about dried up. Rod bearings for a Perkins Diesel engine used in a lot of models of Massey-Ferguson tractors will work if you drill a couple of holes in the bearings to align with the dipper hole and spit hole in the rods. There's also a couple of John Deere bearings that can be adapted to the 216 rod. Jerry
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Not intending to hijack the thread, but the .010" undersize for the converted rods are about $28 - $30/rod. Are the Perkins or John Deere bearings less expensive? If so, can you provide more details for ordering them? (engine, years of use, etc.)?
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Yes, the Perkins bearings are much less expensive. The Federal-Mogul part number is 2015 CPA. They fit Perkins 6 cylinder engines from 288 to 305 cubic inches, with a standard crankshaft size of 2.2485"-2.2490" They are available in Std., .010", .020", .030" undersizes. The bearing OD, which would correspond to the diameter the rods would need to be machined, is 2.3950"-2.3955" It would be necessary to machine a center groove and a couple of oil holes in the Perkins bearing, but any machine shop capable of doing the rod boring should have no trouble with that.
Other bearings with similar size ranges are available that fit Oliver tractors, Mazda Diesels, Mack truck engines, Komatsu, and John Deere. Some would require custom-grinding the crankshaft journals to the proper size to fit the bearings.
I'm in the process of designing a boring fixture for my lathe which will allow me to custom-fit 216/235 Babbit rods to these insert bearings.
Edit: Just found a set of 4 2015 CPA rod bearings on Ebay for $22.95.
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks for all your comments, have to think about my next move.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Jerry, I haven't tried ordering rod bearings, don't have a need right now. But just surfing through Federal-Mogul's online catalog they are still listing .020" under Connecting Rod Bearings "for Connecting rods that have been machined out to take an insert." Sealed Power #1415SB 20, wonder if you can still order them???
DG
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | My friend who runs a machine shop in Fayetteville Tennessee has done several nationwide searches for 20 under bearings over the past 5 years. No luck, and he's in the business of grinding crankshafts and selling parts, not shoveling fertilizer on an internet chat room. He has had to grind several crankshafts down an extra .010 in order to get rod bearings. Parts vendors lie, just like other people. His experience is precisely why I have been researching alternatives to the dedicated bearings. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Jezz Jerry, why in the world do you have to get so obnoxious every time some one asks a question the isn't exactly in line with your way of thinking??? As soon as anyone questions even in a friendly way, or has another view of something, you have to prove to us that you are the all knowing all time expert on just about everything. We all know that you are, you don't have to prove it!!!
It's no wonder people pack their bags and bail out of these 'discussions' when they turn into an abusive rant. All I asked is, have you ever tried?
This happens all to often, I'm outta here, you can have your own little empire all to yourself! Hope you enjoy talking to the wall, it will always agree with you.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | I have mentioned the above difficulty my friend has experienced when attempting to find these bearings, repeatedly. People ignore me and keep dragging out the same tired old suggestions. Getting ignored irritates me.
I could pout, whine and delete all my posts. I choose not to do that. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well Jerry, here's some more of the "fertilizer on an internet chat room" that you so boldly accused me of: http://www.pbase.com/dennygraham/image/159630300/originalThink if it were me, I'd look for a new friend to supply me with .020" under size bearings. And the "Eaton HO52" rear axle only comes in a 4.10:1 (41-10) ratio 68-72, the 37-9 was a Dana/Spicer which is a three piece housing where the Eaton HO52 is a single piece housing. The illustrations referenced in the links to the GM Restoration pacs in the other thread, were three piece housings with the tube pressed and riveted to the center housing, not Eaton. I bailed because I did not want to be part of the misinformation that was being presented. http://www.pbase.com/dennygraham/image/121488060Denny Graham Sandwich, IL
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | It's no wonder people pack their bags and bail out of these 'discussions' when they turn into an abusive rant. ........ This happens all to often, I'm outta here, you can have your own little empire all to yourself! Hope you enjoy talking to the wall, it will always agree with you.
Denny Graham Sandwich, IL Jezz Denny, I thought you were done with this post... from March 21.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | There is always someone in these types of media discussions that doesn't understand the various and completely understandable passions that each side carries. So they try to side with one or the other in some vain attempt to gain favor. It's embarrassing.
Why I come here is because there is a way to resolve all of the BS without much trying even. Rather than depending on friends, or THIS source or THAT source, how about we just stick to the facts in a totally unbiased way? State your sources, the other person states their sources. In doing this normally it reveals that someone is blowing smoke out of their arse, and it all becomes apparent. Research these days isn't a static thing. Google makes it possible for your research to become obsolete THE NEXT DAY!
Nevermind what it has taken 200 years for you to understand, that is all out of the window now because the world has become a much smaller place due to the Internet. Your opinion carries less weight as a super experienced 400 year old as the 20 year old guy who knows how to use Google. Understand it, believe in it, and be humbled by it. How do you matter now? Explain your reasoning in detail saving that information for generations to come.
I try every single day to glean information that will be lost FOREVER because some of our older generation is either leaving us, or forgetting. Rather than Pontificating, and more or less making a total [censored] out of yourself, make this information obtainable thru Google and places that care, like HERE for example. Write down these procedures that matter to you. Make it GOOGLEABLE! Or, just keep yapping to no reasonable end. When you are gone, someone will take your place, maybe several.
If you don't have the GUTS to write How-To Articles for the masses, or at least participate in documenting the history of our craft, please waste our time more! I for one have nothing better to do than listen to years and years of negativity towards any effort to document these things, and give NOBODY anything more than a clue. Congrats, you help the totally clueless. Thats a niche market I suppose, but the minute Mr Clueless learns something, you become insignificant. Join the team of people who actually want people to succeed! What a concept! And you all know darn WELL the people who I am talking about. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What, you see a weak spot and you gotta jump on the negative end of the band wagon too Tom? No sense and arguing and getting cut down without something to back up what you think. So yes, I bailed till I could verify my suspicions. Could I walk down to the local NAPA and buy the brg? No, but if I'm willing to wait a few days I can order them. That they are available was the point.
dg
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | What, you see a weak spot and you gotta jump on the negative end of the band wagon too Tom? No sense and arguing and getting cut down without something to back up what you think. So yes, I bailed till I could verify my suspicions. Could I walk down to the local NAPA and buy the brg? No, but if I'm willing to wait a few days I can order them. That they are available was the point.
dg Denny, No, I didn't even think about a weak spot. No, not jumping on the negative end. No, not going to argue. Not taking sides or trying to side with one or the other in some vain attempt to gain favor. I have no horse in this race. Just get tired of reading these "discussions" when they become abusive and negative and they only whine & pout.. Sorry, didn't mean to offend you. I guess I should have clicked the "NOTIFY" button, like I did the other day, and asked the Moderators if this childish nonsense is acceptable. Thank you to the Moderators for taking swift and corrective action and for deleting the negative post(s).
-Tom
