1 members (klhansen),
107
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,856 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Hey guys, I`m trying to see if there is either a Wagner or Raybestos part number for the 7" brake booster/MC for a 1950 chev 1/2 with 4 wheel disk. Lots of manufacturers in the states, but in Canada at my parts store we usually deal and locate Wagner or Raybestos. Thanks,Darcy | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy darcy32171, master cylinders and brake boosters are usually listed through their application not their outside dimensions. Try Scotts Super Trucks in Penold? Alberta to see if they have the kit you seek, hope that helps. | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Thank you 3B!!! I`ll give Scotts a try | | | | | Joined: Dec 2014 Posts: 32 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 32 | i just got mine from www.speedwaymoyors.com and it is a great kit and afodable with all gm part numbers (except the booster) they also sell individuallt. man it went in with NO modification either with the truck all put together. Biggest issue was removing the old bolts =) i have pics if your interested
Loving my new (old) '53 3100 5 window!
