1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10919 02/21/2003 2:00 PM | Joined: Dec 2002 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 86 | I am getting ready to pull off the cab everything is disconnected but the steering column. What i need to know is can i disconnect it from the box ( if so are parts going to go every where) Or do i have to take the box off the frame.
47.5 Loadmaster 5 window 48 Chevy 3600 69 GTO convertible | | |
#10920 02/21/2003 2:15 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | You do not bother to say what year truck you are talking about, but if it is an AD, you need to unbolt the whole thing from the frame and snake it out. Cannot just remove the column from the box. | | |
#10921 02/21/2003 3:06 PM | Joined: Dec 2002 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 86 | Sorry about that..... Its a 1948 3/4 ton. So i assume i have to unbolt the steering box and slide it out of the cab.
#10922 02/21/2003 4:06 PM | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Yup, what Brian said.
It works great as a two-man job--one inside the cab and one on the other end. | | |
