3 members (klhansen, Otto Skorzeny, KEVINSKI), 87 guests, and 4 robots.
Topics128,130
Posts1,056,706
Members48,454
#1091022 03/12/2015 4:24 PM
I'm going to have to paint my truck in stages. I've seen several examples of trucks with "flat" paint on them and I think a flat paint would be easier plus I like the way it looks. I can't seem to find much information on it, what companies makes it, or how its applied. Anyone have information on this flat paint?
Ron - - Dusty53
1954 Chevy 3604
any paint can have a flattening agent added, see the local supplier of a brand you like, or ask a body shop nearby what they prefer
A good epoxy primer?
Such as PPG DPLF in white or or gray or light-gray or gray-green or red or blue or black?
Bill and Tim, thank you for the help.
Ron - - Dusty53
1954 Chevy 3604
Fox Offline
Not sure what the budget is Dusty but check this out....
May not be up your alley but still an interesting read.
http://www.hotrod.com/how-to/paint-...-affordably-flat-painting/#__federated=1
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
John Deere 'Blitz black' seems to be a popular choice too.
More pix on Flickr.
If you want a good epoxy paint,i used flat matte finish from spies hecker. This was a product from dupont and can now be found by looking up under axalta.This is a paint that is very tough. I have had on vehicle for 7+ years now and still looks good and easy to maintain.
Mike
Even the best epoxy primers do not have the UV stabilizers in them for even short term use. If you want ease and maintenance friendly, put a normal gloss paint on. If it is flat and you have to buff something out, it will end up glossy....
There are a number of less expensive single stage paints on the market. Purchase a gallon of paint and enough harder to paint the item at a time. You will have the actual paint for the whole project, but your not spending the money on all the hardener's and reducers at one shot. My first choice for single stage is PPG Concept. I spray DBC base in my shop and although 2 stage is nice, it can get a little costly.
My next suggestion would be to look at some of the industrial products like PPG Durathane. It can be had for about $60 a gallon and the quality is decent for a vehicle, but it won't lay down as smooth as the automotive stuff does!
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
Not entirely true.
SPI's Black epoxy primer does have UV protection in it and will last for several years with no issues.
I recommend applying 3 coats when you get the piece ready, then you can lightly hit it with 400g prior to painting, then your ready to go with a sealer (The same SPI epoxy reduced) and your final paint.
SPI makes a Flat paint as well.
Give me ambiguity
or give me something else
