2 members (BC59, Uncles51), 103 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#109187 11/19/2004 2:56 PM
I painte my engine about 3 years ago but it was the wrong color. Now that it is out, for a broken crankshaft, I thought I would redo it. What do I need to do to prep it? I am pretty sure that the head will remain in place. Did the bell and the valve cover yesterday. Will second coat it today and maybe do the intake manifold.
#109188 11/19/2004 9:51 PM
Strip it down to bare metal - clean several times with a wax and grease remover - paint it with a self etching primer - then shoot with whatever color you need - you can even use a base/clear urethane if you want.
- Ryan
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
#109189 11/19/2004 10:56 PM
What would you use to strip it?
