| | | Forums66 Topics128,047 Posts1,055,533 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I painte my engine about 3 years ago but it was the wrong color. Now that it is out, for a broken crankshaft, I thought I would redo it. What do I need to do to prep it? I am pretty sure that the head will remain in place. Did the bell and the valve cover yesterday. Will second coat it today and maybe do the intake manifold. | | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Strip it down to bare metal - clean several times with a wax and grease remover - paint it with a self etching primer - then shoot with whatever color you need - you can even use a base/clear urethane if you want.
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
| | | | | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | What would you use to strip it? | | |
