9 members (Gib70, Gdads51, 78buckshot, Phak1, mo2cyl, Oldcaliforniakid, BC59, Wally / Montana, MickeyP), 81 guests, and 2 robots.
Topics128,049
Posts1,055,667
#1091741 03/16/2015 4:35 PM
I'm probably not using the right search terms, but I cant find this info, so here goes. What kind of chassis lube are you using for spring shackles, u joints, tie rod ends etc? I had been using a Valvoline product that is dark red in color. Since everything on my truck is going to be cleaned or replaced, I wanted to check before I start lubing it. Thank you.
Larry
1957 Chevy 1/2 ton NAPCO project
LAJones48 #1091756 03/16/2015 5:20 PM
Sir Searchalot
Sir Searchalot
The brand is up to you. LB is chassis grease. GC is bearings. Find a LB/GC labeled grease and use for both. Not OBGYN or LGBT.
LAJones48 #1091832 03/17/2015 12:37 AM
That's what I needed. Thank you.
Larry
