2 members (Ponchogl, Shardean),
56
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I'm probably not using the right search terms, but I cant find this info, so here goes. What kind of chassis lube are you using for spring shackles, u joints, tie rod ends etc? I had been using a Valvoline product that is dark red in color. Since everything on my truck is going to be cleaned or replaced, I wanted to check before I start lubing it. Thank you.
Larry 1957 Chevy 1/2 ton NAPCO project | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The brand is up to you. LB is chassis grease. GC is bearings. Find a LB/GC labeled grease and use for both. Not OBGYN or LGBT.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | That's what I needed. Thank you.
Larry | | |
