| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 14 Member | | Member Joined: Nov 2001 Posts: 14 | Does anyone out there have a source for the passenger side C-shaped frame that holds the glass in the vent window? The pivot posts have rusted off the two I found here in Florida.The truck is a 52 1/2 ton Chevy | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Try posting an ad in the Swap Meet section, someone there should be able to help. You will need to make sure to mention what year your truck is, too. | | |
