| | | Forums66 Topics128,060 Posts1,055,840 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 22 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 22 | Had my truck about a year. 59 apache 235 with 3 on the tree. The clutch peddle dosent seem to return to the top all the time. The spring setup dosent really look right. After 55 years might not even be the right spring. Does anyone know where there might be a pic of clutch return spring and how it mounts.....
Thanks. | | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | Tobztub 55-59 Factory Assembly Manual (FAM) should have most of the detail you need. Yours should be similar or the same as my '57 3100, on which I continue work. Good details of the clutch assemblies. delky dave in WYO
1957, 3100, v8 2016 gmc 4wd
