1 members (Otto Skorzeny),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Mines bent. Part number is 6.230 I think. Were they all the same (Cars, light trucks and big bolts) during that time period? If not how do I find the right one? Also, If you could point me in the right direction to find one it would be greatly appreciated.
Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy TK421, if the tie rod is not severely bent, it can be straightened and reused, hope that helps. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Who would I bring it to? Machine shop?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy TK421, yes a machine shop would be fine, anywhere with a press, it doesn't need to be absolutely perfect. Once the alignment shop sets the toe the tie rod doesn't see a whole lot of stress, trying to steer while sitting still is the most stress on it, hope that helps. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Thanks
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If just a bow in it and not really a kink you can likely straighten it yourself. I've done so by just using a stake pocket on a trailer, drop it in and pull on it here and there, check and keep at it. Might only take a minute or two. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I have 3 rods about an inch long and 3/4" diameter welded in a triangle to a corner of a welding table that weighs over 1,000 lbs. I use these for for bending jigs for things like this. As stated before, it doesn't have to be perfect and they don't see much stress. They only bend when you back over something like a tree stump. And almost every truck that was used 60 years ago experienced that at least once in its lifetime. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Thanks Grigg. I never seem to think of the easy way out of things.
Andy
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | No problem. I try to always consider the cheap and easy fixes or solutions first. Then work up from there as necessary or to find the best solution given the overall situation and my desires. | | |
