1 members (Rich'sToys),
90
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | Where is the best pick up points for a Suburban without getting under it to put back on chassis?
52 suburban 48 Palace
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I think it depends on what devices are available to you to lift it. I had a big forklift with 8' long forks. We just shoved them through the back opening and blocked up under the roof. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I had 6 friends who lifted the body onto the frame (and at other times). Three per side, front, middle, rear of each side. 6 guys and a worthless foreman. You do not want much strain end-to-end because you could crack joints (such as leaded joints at top outside windshield posts). | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My Suburban's body was painted on the frame.
We placed a 4 mil sheet of plastic covering the entire frame. The body was then lifted over the plastic and placed on the frame. The body was then painted. The paint was then color-sanded/wet-sanded (three people; an all-day job). The plastic was then removed.
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | I used a tractor with a bucket and used two tow straps one thru the door windows and one thru the rear side windows By weeds , , , , | | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | thanks for the suggestions, as usual I forgot the basics like its just spent the better part of 2 years getting all dolled up with new paint and glass. So I was worried putting straps thur the windows. Ended up strap the front, Jack the Back, one man, two come-a longs, one floor jack, wood blocks, and about 5 hrs. Thxs all.
