| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 75 | I was looking at a wagner 890 airless spray gun which has many settings and capable of spraying thick or thin paint and stains. Im wondering why this would not work to prime a fender or hood using etching primer. What you think? Thank's
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | There is no reason an airless spray gun would not work to propel primer onto a hood or fender.
It'll possibly look like a giraffe diarrhea splattered on it, though.
That's probably not the best description, but I've sprayed all sorts of stains & primer & paint through those 'Wagner-type' airless guns. If you just want to coat the metal, it will work just fine, but it will sort of dry to a leathery texture.
Subjective statement: I know you asked if it will work; it will, but it will not look very good.
Brad Wrench Fetcher, PhD | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Given the construction of it, I would question as to whether it can handle solvent based paints. Moth automotive solvent based paint do not play well with plastics, melting them. Same can be said for any seals inside the unit.
Bill Burmeister | | | | | Joined: Dec 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 75 | Thanks Guy's two good reasons I didn't consider, CASE CLOSED ! Appreciate the feed back.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | There is no reason an airless spray gun would not work to propel primer onto a hood or fender.
Brad Nothing a good belt sander couldn't take care of though... Actually a simple RO pad sander and some 80 grit work better, but if it turns out like TANNED leather, well maybe the belt would work.
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | If anyone else has this consideration.... Please don't do it. The main reason that comes to mind is that solvent based paints have a much lower combustion temperature and will easily ignite when coming into contact with things that spark! IE, an electric airless sprayer. I do have an air operated airless sprayer ( Yeah I thought it was funny too) that is used in the automotive world. It was about $3000 for the set up that we used in a high production industrial urethane job.
Buy a decent gun to spray your primer with!
