3 members (j05h79, Phak1, Jay R), 73 guests, and 3 robots.
Topics128,154
Posts1,056,837
Members48,456
#1090493 03/09/2015 8:51 PM
I was looking at a wagner 890 airless spray gun which has many settings and capable of spraying thick or thin paint and stains. Im wondering why this would not work to prime a fender or hood using etching primer. What you think? Thank's
U
U Offline
There is no reason an airless spray gun would not work to propel primer onto a hood or fender.
It'll possibly look like a giraffe diarrhea splattered on it, though.
That's probably not the best description, but I've sprayed all sorts of stains & primer & paint through those 'Wagner-type' airless guns. If you just want to coat the metal, it will work just fine, but it will sort of dry to a leathery texture.
Subjective statement: I know you asked if it will work; it will, but it will not look very good.
Brad
Wrench Fetcher, PhD
Given the construction of it, I would question as to whether it can handle solvent based paints. Moth automotive solvent based paint do not play well with plastics, melting them. Same can be said for any seals inside the unit.
Bill Burmeister
Thanks Guy's two good reasons I didn't consider, CASE CLOSED ! Appreciate the feed back.
Brad
Nothing a good belt sander couldn't take care of though...
Actually a simple RO pad sander and some 80 grit work better, but if it turns out like TANNED leather, well maybe the belt would work.
Give me ambiguity
or give me something else
If anyone else has this consideration.... Please don't do it. The main reason that comes to mind is that solvent based paints have a much lower combustion temperature and will easily ignite when coming into contact with things that spark! IE, an electric airless sprayer. I do have an air operated airless sprayer ( Yeah I thought it was funny too) that is used in the automotive world. It was about $3000 for the set up that we used in a high production industrial urethane job.
Buy a decent gun to spray your primer with!
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
