| | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 52 'Bolter | | 'Bolter Joined: Jun 2013 Posts: 52 | Ok... so we have our truck completely apart and ready to begin modifications. We have a 53 1/2 ton. We pulled the rear axle and plan to replace the pumpkin and housing with a 55 version to get away from the torque tube setup. With that, I know we need to modify the suspension. Do you guys recommend just welding the pivot points on the axle/spring connections or replace with different suspension setup?
If we weld, what is the best place/method to lock the pivot?
If we replace, what would you guys recommend?
Dad and Son are neck deep into our first project, having fun but know the pain already of doing things twice because the first try was wrong.
Dad and Son
53 3100 purchased brand new by my wife's grandfather... full frame up restore in progress.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you are using the '55 housing there is no need to weld anything. The welding is for when one puts the later pumpkin in a torque tube housing.
Ideally, you need the '55 first springs. The mounting holes in the '53 springs are forward of the center of the springs. The '55.1 springs have the hole almost centered. I have read of people drilling new mounting holes and I have read of people mounting the springs reversed. The latter will move the axles aft of the stock location. | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | The original 47-54 wheel is forward of center in the wheel opening of the fender. Is the wheel centered in the center of the wheel opening of the fender on original 55.1 trucks? Carl
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The original 47-54 wheel is forward of center in the wheel opening of the fender. Is the wheel centered in the center of the wheel opening of the fender on original 55.1 trucks? Carl No, it sits forward in the same position as the earlier ones. The difference in the mounting hole locations is due to the hinged mounts attach forward of the axle and the '55.1 mounts are under the axle. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | 1947-54 Chevy 1/2 ton truck Spring Seat 1 and Spring Seat 2 is sitting on top of the leaf spring bolt. The bolt runs all the way through the the stack of leafs. The bolt and the stack of leafs are forward about 2 to 3 inches. The leafs are centered under the spring seat.The axle is centered over the top of the top mono/main leaf. | | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | Guys: If I understand the consensus, I should reverse my rear springs and mount my '79 Firebird rear axle below my reversed springs (leafs) to get a centered wheel in the rear fender opening? Originally weren't the leaf springs mounted above the original axle? My Firebird has a 2.73 posi rear end and will be connected to a 700R4 for efficient and economical mpgs. Comments, please! 54CarryAll | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | This is a Chevrolet 1955 1st series rear end suspension. Pic 1 pic 2 pic 3 The Leaf spring is under axle. That is how to mount your '79 Firebird rear axle. Why are you removing the torque tube set-up? There are high speed ring & pinion gear sets available for those axles. Click here | | | | | Joined: Jun 2013 Posts: 52 'Bolter | | 'Bolter Joined: Jun 2013 Posts: 52 | Thank you for the all the feedback.
The reason for the change is really due to the transmission change we have to make. To run the newer transmission, we need to update the drive shaft and thus the rear end.
The goal was to use the pumpkin out of a 55 truck and use the 53 axles to retain the stock stance. unfortunately, we did not get the springs out of the 55 from which we took the pumpkin.
So we still have the 53 axle and the 55 axle. To retain the stock stance, what is the recommendation for which one to use? 53 seems easiest to use and just weld the pivot points on the spring seats. If so, what is the recommended way of welding or immobilizing that joint?
If the 55 is recommended to use then I from what a read, I need to flip the springs front to back and mount a spring perch on the axles to match up to the springs...correct?
Thank you for all the help and the links.
Dad and Son
