4 members (TUTS 59, PAUL Berardi, wilbur53, 1 invisible), 112 guests, and 0 robots.
Topics128,132
Posts1,056,376
Members48,441
#1089997 03/07/2015 2:00 PM
Leo
Offline
Moderator
Moderator
I'm wondering about the Zerk fitting on the enclosed front U joint bell. My lube chart from Texaco says no lube required. Why is there a grease fitting?
ODSS Lawman
ODSS Lawman
Are you referring to the one on the top that is part of the transmission? That is for gear oil for the U-joint. There needs to be a pint of oil in there but it gets that from the transmission. You only need to add lube if you have opened that up.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Leo
Offline
Moderator
Moderator
Yes, it's on the back section of the transmission. SM420
ODSS Lawman
ODSS Lawman
That's it. Gear oil. Some put a zerk on there to easier lube the joint. I just remove the floor pan in the cab. Much easier.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Only time you need to add oil to that, as long as the trans is
up to snuff is when you've freshly rebuilt it.
The old Bridgeport milling machines has zerk fittings for all
of the ways. Many mistakenly greased those and starved the
ways for oil. There are special oilers for adding way oil and
there were also some automotive oilers that were made for
zerk fittings. Most were plunger type which put pressure on
the fitting as you pushed the oil in.
DG
Denny G
Sandwich, IL
