Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (kades51, DaveV), 151 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#1089893 03/07/2015 12:36 AM
Hi,
Can't believe I'm this stupid, but here goes. A while ago I took the dead battery out of my '58 6 cylinder Chevy pickup. I know I disconnected the negative cable first, but problem is po wired both connections with red cable and I don't recall which way the battery was installed. So my question is this: One cable goes to the starter and the other attaches to the fire wall. Can someone please tell me which goes to the negative post and which goes to the positive. Thanks in advance if you can help me out.
1958 Chevy Apache 3200
The one to the starter is positive.
Many thanks Cletis, I'll be back on the road tomorrow
While you're at it, wrap a couple of layers of black electrician's tape around the ground cable near the battery terminal to remind you that the cable with the black stripe goes to the negative terminal.
The problem is solved...but, the positive battery post has historically been fatter than the negative post. One red cable would have the clamp squished smaller than the other..that would be negative. At least that's how it used to be.
Stuart
They're still that way, Stuart. Sometimes, they make the negative a little too small, which becomes a real problem on late model cars with the steel clamps instead of the old style lead clamps.
Bill Burmeister
