1 members (carbking),
77
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | I have a 235 Chevy and putting on a Fenton dual 1 intake I would like to know should I use two carbs off 1951 216s or two rochesters off 55-57 235's. Also needing to order stainless lines and would like to know if this will be a front or side inlet line. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | From those choices: two 216 carburetors (1951 would be Rochesters - many people would recommend earlier Carters). You still might have "too much" carburetion. Maybe first-hand experience or/and expert advice (Carbking, etc) will be posted.
If you are having lines made to order, you should mock-up your intake, carburetors, and fuel pump (to match the angle on/to the fuel pump and on/to the carburetor, and the distance from the fuel pump to the nearer carburetor) .
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The smaller carbs would definitely be the better way to go than using the larger 235 carbs. Of the two choices, I would personally swing more towards using Carters over Rochesters, just based on my experience with the Rochesters (cracked housings, warped cases seem to be common on those). Having said that, my personal favorite is the Holly 1904. Easy to overhaul, jets are the same as the Holley 4 bbl and are easily found at most parts stores. Only real issue is floats are almost impossible to get, and the throttle arms tend to be backwards from a GM carb.
Bill Burmeister | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | When I did the 235 engine on the 48 2 ton I used an Offenhauser intake because I could get it for the earlier small base carbs or the later large base carbs. don't see Fenton offering a choice. I wanted the smaller because two W-1 Carter's had more than enough CFM rating that the engine needed, wasn't going racing. | | |
