| | | Forums66 Topics128,094 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | I have just finished mig welding couple patchs and the welds arent 100 per cent good. is there something I can put over the welds fiberglass body filler ?? to keep moisture from coming from backside ?? or could i use a 2 part epoxy ?? prior to leveling with reg body filler. hopefully my next patchs will have better welds!! | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | More weld is the best option. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are talking about the inside surface on a cab patch, I wouldn't bother unless it is going to get wet etc. In that case use body seam sealer. | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | If you want it to be a permanent patch and not come back to haunt you after it is painted it has to be 100% welded! | | |
