6 members (Gdads51, tclederman, 1955 1 Series, Otto Skorzeny, chemanic, 68ironhead), 134 guests, and 2 robots.
Topics128,082
Posts1,056,303
Members48,441
Junior Member
Junior Member
There are probably two dozen '66 trucks within 300 yards of my house, but none of them, including mine, have any trace of the under-bed
mounting brackets. What did they look like?
The money I save as a mechanic, I spend on medical bills!
I used one from a 69, looks just like the one under the 87 I had, simple two-bolt strap-type carrier. Sorry I have no pics. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Junior Member
Junior Member
I hope someone can post a picture. I don't see any obvious connection points on the underside frame. The center joist(?) has three 5/16-3/8 holes in it (with a bolt with an empty crimp lug in the middle hole - maybe it was a ground?).
JimG, I have a '66 C10 longbed Fleetside that's all original with only 14000 original miles.It still has the Orig. U.S Royal, bias ply spare tire, & it's mounted in a standing position, inside the bed, up against the (right side) inner bedside. It has a Factory looking stand with a threaded stud for the tire to bolt onto. There's nothing under the bed.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Both in bed & under bed carriers were available. No obvious signs under truck because they use holes already drilled in the frame, one bolt on each framerail. Carrier mounts at an angle, pass side is near the bumper. See if you can find a 73-87 to look at, I have no clue how to post pics.
