5 members (TUTS 59, Gdads51, massey1951, JW51, sron48), 92 guests, and 2 robots.
Topics128,038
Posts1,055,583
#1089383 03/04/2015 6:46 AM
Can anyone help me out with a current part number or source for an exhaust down pipe for a 1945 1 1/2 ton truck with a 235 in it? I am looking for the pipe that starts at the manifold, goes straight down (I assume) and then turns rearward. I don't have the old one or the flange to know what it is supposed to look like. If I need to have one custom bent is the flange a common piece to get?
Memphisdoug #1089395 03/04/2015 11:17 AM
Doug,
It should be the same as found on smaller trucks; however, there are two different exhaust manifolds either straight dump or angled. The flange is a cast iron piece. If you cant find one locally, I have a spare.
Paul
Lots more pictures
My 43 1.5 ton looks to have been made at a shop, not a factory part (to many welds). The part number for the flange is Walker 31851 Hardware Flange on Amazon.com.
The only real concern is as Paul_WNC stated... you need to look at the exhaust manifold.. the early 235s go straight down, the later 235s angle about 45deg.
