| | | Forums66 Topics128,139 Posts1,056,462 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 24 Junior Member | | Junior Member Joined: Feb 2003 Posts: 24 | There are probably two dozen '66 trucks within 300 yards of my house, but none of them, including mine, have any trace of the under-bed mounting brackets. What did they look like?
The money I save as a mechanic, I spend on medical bills!
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used one from a 69, looks just like the one under the 87 I had, simple two-bolt strap-type carrier. Sorry I have no pics. Brian | | | | | Joined: Feb 2003 Posts: 24 Junior Member | | Junior Member Joined: Feb 2003 Posts: 24 | I hope someone can post a picture. I don't see any obvious connection points on the underside frame. The center joist(?) has three 5/16-3/8 holes in it (with a bolt with an empty crimp lug in the middle hole - maybe it was a ground?).
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | JimG, I have a '66 C10 longbed Fleetside that's all original with only 14000 original miles.It still has the Orig. U.S Royal, bias ply spare tire, & it's mounted in a standing position, inside the bed, up against the (right side) inner bedside. It has a Factory looking stand with a threaded stud for the tire to bolt onto. There's nothing under the bed. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Both in bed & under bed carriers were available. No obvious signs under truck because they use holes already drilled in the frame, one bolt on each framerail. Carrier mounts at an angle, pass side is near the bumper. See if you can find a 73-87 to look at, I have no clue how to post pics. | | |
