8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 37 | What size tires and wheels will fit inside the rear fenders with the truck sitting at stock height. The truck came to me with 255/60/15 tires and they are to small. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This site covers trucks from the '20s to the '70s. Pick one. | | | | | Joined: Jan 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 37 | SORRY !!! it is a 49 3100 thanks for the heads-up | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Stock height might be different depending on if you have new springs or the originals. Also, are you talking about stock sized wheels or aftermarket? Stock offset or not? You'll need more information to get a good answer.
Also, are you just wanting wider or taller as well? | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I've got Michelin LTX 245-75R-16s on the back of my 51 panel & an Olds rear end. 8 inch rims with standard offset. The truck is about 3 inches lower than stock in back. These meats fill the wheel well!
