0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Assembly plant photo Someone save this picture......g Can anyone pinpoint the year of this one?  | | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | Well.......I sure ain't gonna reverse the process to replace my floor. Looks like pre painted and everything! | | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | | | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Cool pic! Do you have anymore that show them putting the rest of it together??
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pic of the next step here .... the e-bay one looks like a 1 ton? Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | If you look carefully you can see the louvers on the drivers side indicating it has the side vent making it a pre-1951. There is another clue that I think maybe Tim Lederman might figure out. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Good observation Bill, the lead photo is a 1 ton and the one forward panel is a 1/2 ton. I can tell you that the suburban is either a 1949 or 1950, but I can't pinpoint the exact year. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | how about the clue in the name of the picture  Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | how about the clue in the name of the picture  Bill There are only so many parts visible in the picture, most of them are discernible by year or limited to a few years. The clue is obvious to those of us that have had this discussion in the past on components that were discontinued and replaced with a different component. In the photo you provided showing the suburban, the giveaway for me was the extra hand hole close to the front door was added in 1949 and it appears to have the louvers on the drivers side cowl, so it is post 1948 and pre-1951 BTW: I could be wrong with the panel component, because it takes a little imagination and assumption on my part due to the size and quality of the picture. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I meant the ebay pic is named "52-1952-Chevrolet-Chevy-Panel-Truck ...."  otherwise I'd think the bumper shape might be a clue and dash layout/holes, not as familiar with the ADs I knew the panel bodies were built on the floor assembly, I recall line pictures in an old Golden State catalog that showed some of it, including the completed body with front clip being lowered onto a chassis, thought I'd sacanned and saved them, but don't find'em now Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I am a little confused on what is being identified.
The first link is of 1950 or later A-D panel trucks (number of planks is a give away, earlier years had 13 boards and 12 "skids" ). The rear truck looks like a 1-ton.
Bill's link is to an A-D Suburban, which only came in 1/2 ton. It is a pre-54/55 Chevrolet/GMC dash.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I am a little confused on what is being identified.
Bill's link is to an A-D Suburban, which only came in 1/2 ton. It is a pre-54/55 Chevrolet/GMC dash. I know the title of the picture states 1952, I think I see louvers in the left side cowl, that would mean pre-1951. If it is truly pre- 1951 then Tim is on the right track and we should be able to date the truck from this picture. If I am wrong about the louvers, then it is probably a 1952 as stated. | | | | | Joined: Nov 2012 Posts: 259 Haunting the SBP since 2001 | | Haunting the SBP since 2001 Joined: Nov 2012 Posts: 259 | Cool pic! Do you have anymore that show them putting the rest of it together?? Here's one . | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | The first link is of 1950 or later A-D panel trucks (number of planks is a give away, earlier years had 13 boards and 12 "skids" ). The rear truck looks like a 1-ton. Bill's link is to an A-D Suburban, which only came in 1/2 ton. It is a pre-54/55 Chevrolet/GMC dash. Does this mean All 1947-1955 1st Advance Design Suburbans had a plywood rear floor? Where as the 1947-49 panel truck had planks & the A-D Suburbans never had planks, only had plywood.? As per Jim Carter below: Panel Truck Wood Floor Changes "It appears this was the same size that was used with the flat floor board Suburban." One Piece Panel Truck Floor "It now followed the example of the Suburban by using a one piece, 5 ply floor."
Last edited by jorb; 08/26/2013 6:33 PM. Reason: Corrected years A-D Panel trucks had planks for rear floor board/cargo area.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | All 47-55 Suburbans had a plywood floor.
My mistake was to make it clear that in 1950, the Panels' rear floors changed from 13 boards and 12 metal skids to 5 skid strips and a plywood board.
| | | | | Joined: Feb 2009 Posts: 8 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 8 |
It ain't easy being me
| | | | | Joined: Sep 2003 Posts: 3 New Guy | | New Guy Joined: Sep 2003 Posts: 3 | Some great info here , George. (long time, no hear)
ensoniqman
