1 members (mick53),
202
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | A product called never -dull,it works great on chrome, comes in a silver can ,you can get it at most auto stores, old navy 51................ | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | I have had good results with autosol. You might want to try Mothers products. I recently bought some to polish aluminum and it worked well, I am sure the store had Mothers chrome polish also | | | | | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | From the looks of the pic, I don't think anything is going to help but a rechrome. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Don't waste your money on Never-Dull! The stuff doesn't work. If you don't believe me, you can have an almost full can I have.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | I've had good luck with Wenol products but AD-53 may have the correct solution.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Cletis - don't make the same mistake I made and have your grill rechromed. I cannot bring myself to put in back in the truck as it looks too good and makes the rest of the truck look shabby. I bought another old grill to install in my truck till I get around to fixing up the rest of the truck, the chromed grill will go into a suburban I am building instead. I had some really rusty hubcaps on my '35. I used rubbing compound mixed with autowax and a very fine steel wool. I coated them well and then let them sit till they dried throroughly and then polished them with an old diaper. The key is being very gentle with the steel wool and being very agressive with the polishing after it is dry. [img] http://www.kinemation.com/Trucks/Images/before.jpg[/img] [img] http://www.kinemation.com/Trucks/Images/after.jpg[/img] They aren't perfect, but I felt I had nothing to lose as they are not originals and were very rusty to start with. They have stayed nice and shiney with the coat of regular old car wax the last couple of years. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Wow, that is impressive. Looks like I need to pick up some steel wool when I'm in town tommorrow. | | | | | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Nah cletis, no steel wool, just a 12 pack and some cheap Mothers chrome polish. Sucks to be the man polishing, but elbow grease solves the problem--my grill was from just off the gulf coast and looked like crap, but fifty beers later, a laughing wife, and some junk chrome polish, and it looks great. And I'm Polish (kinda-and Irish...  ).
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
| | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Cletis I second the Toothpaste that Metalman mentioned. It is very gental but works and you dont smell bad when you are through! Before you try the steel wool try some aluminum foil.
Good luck!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I saw on the show MYTH BUSTERS, they put Pepsi Cola and tin foil up against several leading chrome cleaner. The result was that Pepsi and tin foil worked a lot better than the chrome cleaners. You get Tin foil and wad it up into a ball and then you pour Pepsi over the surface of the chrome and scrub away. I haven't tried it yet my self. Any body ever tried the Molasses and water treatment? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I went to Ace Hardware today. They didn't have autosol, wenal, neverdull. Forgot to look for gel toothpaste (didn't put it on my list). They had a Mothers polish but it was light weight. Label said if badly tarnished use Mother's something else and they didn't carry it. So I got some rubbing compound and steel wool.
It didn't work. There is no chrome to polish in those spots. Something has eaten into the next layer of plating. Polishing it just makes it look worse.
A good wax job did make it look better from a distance. I guess I'll use it as is. I'm not building a show truck anyway. It will be a 50/50 driver.
If I do some day happen to find a couple thousand dollars laying around in my sock drawer I have a cherry painted grille in a '53 2 ton I can have chromed. The insert is the same as the 1/2 ton. | | |
