1 members (klhansen), 114 guests, and 5 robots.
Topics128,260
Posts1,058,342
Members48,485
I need to know the best source to buy correct size clutch and brake pedal pads for my 1958 3600. I Ordered and received 2 covers that were too small, they looked like they were for a pre- 55' truck; the catalog had the cover part # for 47' to 59', too small for my '58. Help!
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
some places do list the pads as 47-59, Jim Carter doesn't, they list AD and TF as separate numbers - OTOH, Steele rubber lists one size for the TF [3.5" x 2.5"] but 2 sizes for the AD, one the same size and one bigger at 3.75" x 2.375" headscratch measure your metal pedals - I forget where I got mine, but probably Carter - they are a real tight fit, necessary to roll the flap back some to wrastle them on, but you don't want them loose
Bill - Thanks!!! I will call Carters' tomorrow to see if there part FL176 will fit my 3.59 x 2.35 pedals. Steele is proud of their parts with both size pads over $20, I may have to go that way to find the correct fit. I will find out if the size listed is the outside dimension, the set that I ordered have that outside measurement.
"Calvin"
Moderated by  ndkid275, Phak1
