2 members (2 invisible),
84
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 9 New Guy | | New Guy Joined: Feb 2015 Posts: 9 | I have a 12' all wood flatbed. It has a 1/4 inch by 1 1/2 flat metal band around bed with stack pockets bolted to 1 1/2 inch by 6 inch wood board and welded on bottom edge to metal rail.Everything is wood until it is u bolted to frame. Is this a factory flatbed or were all the flatbeds made locally. This looks to be original whoever made it. Also what makes this a one and a half ton or 2 ton. It has double stacked leaf springs and a single speed rear end.I will post pictures soon.Reddog 46 :cool: | | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | Pictures would help. A single speed rear usually, but not always, indicates a 1 1/2 ton. | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | My 46 2-ton has a single speed rear end. As I understand, if you have bolt dust covers on the front axle it is a 2-ton. If it s threaded on dust cover it is a 1 1/2 ton.
Not sure about the bed. Post a link to some photo's and I'm sure someone will chime in!
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I don't have it in front of me, but the Salesman's Info book would help with both of these questions. It has drawings of the trucks available, including the stakebeds, though I don't know how much detail they give.
It also specifies the equipment for 1 1/2 vs. 2 ton trucks. Pretty sure it's largely wheel size and suspension, though there may be a difference in frames. I'll check tomorrow.
-Michael | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | Check the serial number tag on the right hand side of the cowl. If the it starts with PV or PW, it is a 2-ton. The 2-speed reared was optional equipment It was up to the original purchaser to decide if it was needed for the truck's application. The flatbed could be from GM, an aftermarket up fitter or home made. Many farmers would build their own to save a little money. | | | | | Joined: Feb 2015 Posts: 9 New Guy | | New Guy Joined: Feb 2015 Posts: 9 | My plate says 6PK-F - 1070. It also has 7:00x20 tires and wheels.These tires and wheels seem to just clear the front fenders. It seems that other trucks sit higher of the ground than this truck.Also one odd question ,why would one backing plate in the rear sit inside the wheel and the other is outside the wheel edge. I have not taken off the wheels but they seem the same on each side? thanks Reddog46 | | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | You probably have wheels with different offset. In 70 years time, who knows what someone bought out of a salvage yard. Its not always the case, but earlier wheels tended to have less offset. Could be one is an earlier wheel. There are lots of wheels with the same bolt pattern. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | 2 tons also have a large 3/8"? plate that runs on the outside frame rails, That has always been my quickest telltale as to the size difference between the 1.5 to 2 tonners. | | |
