4 members (Hotrod Lincoln, fonz8261, Hugh63c10, kbenz), 167 guests, and 3 robots.
Topics128,128
Posts1,056,660
Members48,450
#1088207 02/27/2015 5:49 AM
So I bought what I thought was an nos rear fender for my 39 1/2 ton jc truck.well I go to put it on and it didn't fit.the part where it bolts to the running board is way of and more narrow than what I have on there now.any ideas as to what it might be from.it looks exactly the same as the 39 but the fit is off.all help is welcome.
A lot of time it's just a matter of adjustment. Hopefully there is a little play in the fender mount holes. I would loosen the running board. Over time body parts just shift and possibly even the frame is slightly out of whack which would mean body panels are too. It doesn't take much shift to transfer into alignment problems. Fitting panels and fenders takes patience and trial and error.
Drew
Maybe the fender is a '40-46? If I remember right the fenders got narrower in '40 when the bed got wider.
Dennis
40 Chevy 1/2 ton
soo sorry i meant front fender not rear.
