Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including Click on image for the lowdown.
1 members (baldeagle),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There was a recent conversation here about installing a magnet in a differential. I did not comment on this at the time, but I just posted some pictures on my BLOG about what I do.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Works for me- - - -now, how about a rear axle cooler? We used them on round track racers and extended the life of the bearings and gears about 25% or so. Putting a fitting above the ring gear at the top of the housing used the splash off the gears to pump the fluid through a small transmission cooler mounted inside a frame rail. The return line went into the left side axle tube a couple of inches outboard of the housing. Jerry
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I run my trans cooler under the bed, maybe I'll put a diff cooler too. As for the magnets. Engine,trans and rear have them. So far so good. My magnets are external. A mother to remove... You could loose a finger.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Jerry, never really heard tell of such a thing. Wouldn't think the ring gear could throw much oil up a fitting through a line to a cooler??
John | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Think about the speed of the ring gear, and how fast the spray from it can be at racing (or highway) speed. That's why a lot of differentials have a passageway cast into the carrier housing to lube the pinion bearings. Putting a 3/8" pipe threaded hole at a tangent to the ring gear allows a good bit of lube to be diverted through the cooler lines, especially at operating temperature when it thins out a bit. Jerry
| | | | | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | Geez, Wish I had remembered to put a magnet in the Diff housing when I had it apart. Just got it back together this past weekend.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Magnet is better than an oil filter for small stuff. The cooler idea is new to me, but makes sense. I never really thought about the heat involved.....dur. Thanks!
Steve H
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | The "slip" action of hypoid gears creates a lot of friction and heat. The older centerline-mounted pinion gear like the banjo-housing Fords ran a lot cooler than when the engineers decided to lower the floorboard height by putting the pinion gear off center toward the bottom of the ring gear. Hypoid gears are quieter, and somewhat stronger than centerline gears due to the increased surface contact of the hypoid gears, but they're a lot more tricky to get the tooth contact pattern set up right. Jerry
