0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#108744 12/07/2004 9:11 PM
Apprentice
Apprentice
can any one help me in figureing out how i should go about painting the under side of my truck so i don't have to worry about rust near as much
1940 1/2 ton chevy
#108745 12/08/2004 1:54 AM
Oh boy, here we go!! One easy answer would be go to www.zerorust.com and study the info there. Several users here who can speak with authority too. There will more than likely be others who pop in with other options as well........
Bruce Palmer
[email protected]
#108746 12/08/2004 2:28 AM
Apprentice
Apprentice
thanks Bruce that is a lot cheaper than one i found it is called POR 15 it sounds like a dream come true but wow is it expensive
1940 1/2 ton chevy
#108747 12/08/2004 6:24 AM
Attached is a link to a POR/ZR test done on the motor mounts on a saltwater fishing boat on the east coast. The pictures were taken after 16 months as memory serves.
http://www.autobodystore.com/images/boattest.jpg
Bruce Palmer
[email protected]
#108748 12/09/2004 2:41 AM
I
I Offline
Ok so at what temp can I use the Zero rust. Here is IOwa it is cold but I need to complete the chasis painting asap. Does it have to be abouve a certain temp for a long time to cure?
#108749 12/09/2004 2:58 AM
i blasted my frame got a gallon of hemerite gloss black and a few spray cans of it for the tight places painted it last summer its setting in the rain not a speck of rust showing very good stuff yuo could put it on without blasting because it incases the rust and stops it 60. for a gallon
#108750 12/09/2004 6:12 AM
Minimum temperature for applying Zero Rust is about 55F. This is pretty standard for kicking solvents from the film allowing the film to flow out. Anybody tells you much lower than that, check it out. Applying heat to the piece before shooting in a cold environment will help as will moving air across the work to help pull solvents. Just be advised there is no substitute for some heat to "GIT'ER DUN!!!!
Bruce Palmer
[email protected]
#108751 12/10/2004 4:26 AM
I
I Offline
Bruce - 55 sounds good for painting and getting it to flow. But...I thought Zero and others need to "cure". Does it need to cure at 55 or will X (4 or 6, etc) hours at 55 do the job and then let the temp go colder? It would be difficult to keep my garge at 55 for several days. I need to figure this out asap as I only have about 5 weeks before the body goes back on.
