| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Awhile back I asked about using Mar-k's POR15 method of bed painting and got some great advice from several of you. Here are pics as it is right now. Slowing going lately as the weather has been awful. By the way, the hardest assembly part for me was locating the side board mounting holes. Using the marker system was not accurate for me. I am blaming on an age/eye thing.  I decided to use a sacrificial cheap pine board cut to the same dimensions to get the holes right. It took just two tries, but if I hadn't done that I would have missed the board holes by 1/4-3/16 inch. Not good. Anyway, here's a fitting pic and qa painted board pine pic. The paint looks glossy, but that's the flash. [IMG] http://pic100.picturetrail.com/VOL1061/3611363/24628191/410838056.jpg[/IMG] [IMG] http://pic100.picturetrail.com/VOL1061/3611363/24628191/410843317.jpg[/IMG]
Drew
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Awhile back I asked about using Mar-k's POR15 method of bed painting and got some great advice from several of you. Here are pics as it is right now. Slowing going lately as the weather has been awful. By the way, the hardest assembly part for me was locating the side board mounting holes. Using the marker system was not accurate for me. I am blaming on an age/eye thing.  I decided to use a sacrificial cheap pine board cut to the same dimensions to get the holes right. It took just two tries, but if I hadn't done that I would have missed the board holes by 1/4-3/16 inch. Not good. Anyway, here's a fitting pic and qa painted board pine pic. The paint looks glossy, but that's the flash. [IMG] http://pic100.picturetrail.com/VOL1061/3611363/24628191/410838056.jpg[/IMG] [IMG] http://pic100.picturetrail.com/VOL1061/3611363/24628191/410843317.jpg[/IMG] That looks real good So is that por 15 and paint or just por15 | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | POR15 top coated with Behr exterior paint.
Drew
