4 members (Shaffer's1950, Ponchogl, mick53, Hotrod Lincoln), 150 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
I'm installing a 305 sbc and a turbo 350 trans with a 6in.tail shaft in 53 GMC 1/2 ton Long Bed P. U.( 78 in.) I have a 68 le mans rear.I want to use a one piece driveshaft do I need a longer tailshaft to make this work. Can I make it work
Sir Searchalot
Sir Searchalot
Normally you get the donor drive shaft shortened or lengthened to fit between Trans and Rear if that's what you are asking. You also have the proper yokes/slip yokes put on at that time. Measure once and pay twice.
My question is : Will that distance be to long for a single drive shaft
Just a small piece of advice, load your truck onto a trailer and take it to the driveshaft shop and let THEM do the measuring. Any mistakes will be on them. Don't ask me how I came to that conclusion.
Call a local driveshaft shop, they're the experts on what length is too long.
My 46 GMC on Photobucket
Sir Searchalot
Sir Searchalot
If you are saying that you think it's about 78" that is considered Loooooong, the answer will be either how long they can do on their equipment or what is a doable diameter/wall thickness for that long. It really boils down to RPM vs rigidity of the shaft. Many say 72" max. There are vehicles with 80. As said, the answer can only be gotten from whomever is going to build it. You can call several shops to see if you get the same answer. You may see longer shafts on this or that. Does not mean anything. Many long beds are two piece. More modern equipment/materials may enable one piece. Two piece will be greater hassle/expense.
Bingo!
For some reading on he subject try the Spicer Driveshaft Applications Guidelines
found linked in this tech tip
http://www.stovebolt.com/techtips/driveline/setup/index.html
You can have a long driveshaft if the RPM is low enough and the tube diameter is large enough... along with some other considerations. Figuring out what is safe and reasonable takes some head scratching and or expert advise, like from a driveshaft shop and the Spicer literature.
Sounds to me like a two piece shaft will be the safer option, but worth running the numbers and investigating all options.
•1952 Chevrolet 3800 pickup
---All pictures---
I think he is saying he has a 78" bed, not that the shaft is 78" long.
Have you set the engine and trans in place? Do you know where the back of the engine will be? That's the first step...
Once you know where the back of the engine will be start measuring from there back to the rear U-joint, Then start measuring transmissions and subtract them from the first measurement taken to come up with a rough shaft length. Now that you have a rough measurement you can ask the experts if it will work or not.
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for the GOOD advice it's 78 in. bed not drive shaft length. I will talk to experts at local drive shaft shop .I heard there really good
