2 members (greenie-reddy, KEVINSKI), 116 guests, and 6 robots.
Topics128,266
Posts1,058,367
Members48,485
#1087416 02/23/2015 4:13 PM
ON my 59 Apache with a 235 6 cyl. and a remote oil filter. The Oil lines in & out are bad. The parts catalogs don't show any, one place had some but had wrong fittings on the ends. Better off trying to have some made ?? Hate to use a hose barb style fitting and a hose clamp.....
Any help.....
Got mine from National Chevy Association Parts. Chevy of the 40's also carries them in their oiling section. Around $35.00-$40.00 per set.
Tim
1970 VW Beetle
Chevs of 40s hoses - about $40 for pair - no fittings (lengths are shown)
National Chevy Association - $60 set/pair - includes fittings (lengths are not shown)
Classic Parts of America - 2 lines with fittings - $35 (lengths are shown)
Jim Carter - 2 lines with fittings - $35 (Lengths are shown) He also sells lines separately
Check out the line lengths that you need. I have received lines that are too short.
Tim...
Thanks for all your help.
Tobtub59
Another alternative would be to take your original hoses to a Napa, Tractor Supply, or any other place you might have locally that makes hydraulic lines. They should be able to make you a set with the correct ends and length, and could possibly be less expensive.
Bill Burmeister
back yard wrench turner
I made my own with hard brake lines and a couple of fittings from my Ace Hardware. Spent about $12.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I also did the same as Wayne, Coated brake lines from Napa, The look great too.
